Building my first 8" Nozzle with clear tube.
Building my first 8" Nozzle with clear tube. Empty Building my first 8" Nozzle with clear tube.
Post  projeto Fri Aug 07, 2009 7:12 pm
Here is a CAD drawing of the design i will be using for my clear 8" nozzle. I wanted to try a clear tube to be able to see the water flow. Please let me know if this design looks good.
Building my first 8" Nozzle with clear tube. Nozzle2
I will be using a 7mm SolidCore fiber optic with some light source, (have not figured that out yet) any suggestions?
projeto
Building my first 8" Nozzle with clear tube. Empty Re: Building my first 8" Nozzle with clear tube.
Post  covewi Fri Aug 07, 2009 8:25 pm
Heres a good source for clear tubing - but its expensive.
http://www.eplastics.com/Plastic/Plexiglass-Cast-Acrylic-Tubing
Your project looks great.
You could run water through it and then introduce a food coloring or some other dye to study the flow patterns of the water through the entire fountain.
It would give all of us some great insight into the fluid dynamics of laminar flow.
Building my first 8" Nozzle with clear tube. Empty another link
Post  colinley Fri Apr 02, 2010 2:23 pm
here is another link from ebay a bit less expensive
http://cgi.ebay.co.uk/150mm-x-3mm-Clear-Plastic-Tube-Perspex-Rigid-Tubing-1m_W0QQitemZ300404639697QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item45f18307d1
colinley
Post  colinley Fri Apr 02, 2010 2:26 pm
sorry that was for 6 inch this link is for 8 inch
http://cgi.ebay.co.uk/200mm-x-3mm-Clear-Plastic-Tube-Perspex-Rigid-Tubing-1m_W0QQitemZ290411239591QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item439ddbd8a7
colinley
Post  liteglow Fri Apr 02, 2010 3:02 pm
That is an impressing drawing :-)
I`m working with AutoCad 2010, but I have not yet figure out so much.
btw, do you want to share that cad drawing? :-)
