My fountain
My fountain
Post  ting5918 on Mon Feb 15, 2010 8:45 pm
Dear all
i can't show my picture.
thank you Jonh
can see on http://www.flickr.com/photos/11687882@N03/4367533042/
ting5918
Re: My fountain
Post  John on Wed Feb 17, 2010 7:28 am
It's best to show pictures by using an account like flickr or photobucket. Then you can just use links.
I really want to see your fountain!
Re: My fountain
Post  ting5918 on Fri Feb 19, 2010 7:18 am
1
ting5918
Re: My fountain
Post  ting5918 on Sat Feb 20, 2010 1:19 am
I mounting BLDC motor for cutting and contorl by PIC 16F627A.
High power led mounting near nozzle and heat tranfer by aluminuim lod.Then connected led to driver supply.
Now I lookingfor 9w RGB high power led.
ting5918
Re: My fountain
Post  liteglow on Wed Feb 24, 2010 10:19 am
Hi And welcome Smile
There is not so much activity on this forum because of the winter time Rolling Eyes
Anyway, I love your pictures Very Happy
The laminar jet seems awesome, powerful and with a high beam.
Do you have some building photos?? how did you manage to get so bright light, i love it !!Smile
About sharing photos, photobucket.com is free and very easy to use Smile
cheers
Filip
mounting led
Post  ting5918 on Wed Feb 24, 2010 6:30 pm
I did mounting led near the nozzle .
How to do?
Put the led to end of aluminum rod (use aluminum because it can transfer heat) next wiring cable of led to pcb then use rasin for insullate. So may be claer Acrylic for insulate.
i will show this picture later.
ting5918
Re: My fountain
Post  John on Wed Feb 24, 2010 7:01 pm
ting,
I like your method of using clear materials for the top part so the light shines more everywhere. What did you use? And what did you use for your cutter? Steppers? Solenoids?
Re: My fountain
Post  ting5918 on Wed Feb 24, 2010 7:47 pm
Clear materials means acrylic rod+ resin.then mounting led to aluminum lod by glue and next use acrylic and resin for insulate.
The cutter is BLDC motor (coolling fan of pc)and bring any circuit out and then i should have fromcoil+ironcore and permanance magnatic after that fix the position of them for cutting because BLDC MOTOR can be rotate 90 degree per time and should be fix it from 0 degree to 80 degree(because BLDC motor design for 1 direction) .So i fix it by something can be stop it(stopper).Next i control direction of motor.So becarefull about current of drive motor I was test it have 2Amp in to motor there are no good and sould be control direction of motor about 1sec for limit current and protect motor.
So i will show my picture later after i make a photo.
ting5918
bldc motor
Post  ting5918 on Wed Feb 24, 2010 8:13 pm
this it 's my bldc motor http://www.flickr.com/photos/11687882@N03/4386695648/
ting5918
Re: My fountain
Post  liteglow on Thu Feb 25, 2010 2:59 pm
More pictures of your inside LED module thanx Very Happy
I maybe think I will do the same as you..
Because all the job with the fiber take to much time Surprised
Re: My fountain
Post  ting5918 on Thu Feb 25, 2010 11:18 pm
liteglow wrote:More pictures of your inside LED module thanx Very Happy
ok i will make a photo of mounting the led .
ting5918
mounting high power led
Post  ting5918 on Wed Mar 10, 2010 8:46 am
mounting led on aluminum rod on http://www.flickr.com/photos/48269995@N02/4422176607/
ting5918
Re: My fountain
Post  liteglow on Sat Mar 13, 2010 5:01 am
ting5918 wrote:mounting led on aluminum rod on http://www.flickr.com/photos/48269995@N02/4422176607/
Great Very Happy
But what LED is that? and where did you buy it.
Was not so easy to see it on the pictures!
Re: My fountain
Post  ting5918 on Sat Mar 13, 2010 6:06 am
Sorry for picture. So i take the photo by myself . I will be make a new one of nozzle and I will be make a new picture on next week.
I buy led from alebaba.Because in my country no have led 9wRGB so if you see my pic .It is not enough space for mounting. After this I mounting led on PCB then I using glass rod put on led but not work.(like you but ypu using fiber optic) Now I make a program for control them So i think i will complete as soon.(led 9w RGB 1SET =3.50U$)
ting5918
Re: My fountain
Post  liteglow on Sat Mar 13, 2010 7:31 am
Ting: Your doing a great job Smile
Love the light you have from your LED setup !
Re: My fountain
