What do you think? [SIZE]
I'm not getting the results from a 6" tube that I wanted.... While I have not solved for all-things, I am using brass inserts from John. Last night i found an odd tube. Its ID 13"x3' - so if cut in half; i could make two 13" round by 1.5" nozzles. I'm pretty sure I've read that the larger the diameter the better the nozzle...
Your thoughts?
Your thoughts?
Gator- Nozzle Newbie
Re: What do you think? [SIZE]
What distance and height should I get from a 6" tube? I'm only seeing about 6feet and 2foot arc.... I'm trying to get a 6foot arc and 7-8ft in distance. Is this NOT possible with a 6' tube? Pressure isn't an issue - wonder whats wrong....
» What Pump to use ?
» How to size your pump
» size of the straws
» Ideal Pipe Size?
» Just Curious, Inlet size?
» Ideal Pipe Size?
