Need help do build a functional cutter !
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
It`s late summer now, and I still have not used my 2 laminar nozzles
And that is only because I dont have any cutter that works !!
My first cutter was 2 solenoid electric magnets pushing and pulling a metal shield on the water output.
The metal shield was mounted with a screw and a hole..
Problem is that the water pressure is so hard on the metal, that the solenoid dont manage to push and pull it back!!
And I cant place the nozzle under the ground when I know after 1-2 hours the cutter dont work anymore
So I need help and advice (pictures) how I can build a cutter that will work everyday!!
I have 2pair of solenoids to use on the cutter.
Problem is what blade should I use, and how should it be mounted ??
plz some advice
liteglow- Admin
Re: Need help do build a functional cutter !
Yes please, I am struggling with the cutter too, for a while now. The cut is clean buy I can't manage to get the water away from the stream so the Un-cut is also clean. I'm using a linear actuator by the way.
scrafy- Nozzle Newbie
yes to remove the "cutting" water splash away from the output hole is not that easy !
Anyway, I can live with a "bad" cut if it will work 100% every day.
liteglow- Admin
Liteglow,
I spent a lot of time refining the cutters for the nozzles for my pool, for all of the nozzles I've built, they are the only ones that use cutters. I'm on vacation so without pictures this may get confusing but I will do my best to explain. I love keeping things simple, this may sound complex but truly it's not.
- First I fabricated a tower that sits 1 1/8" above the nozzles output, this tower is hyperbolic in-shape " very similar to the cooling tower of a reactor". I built them by shaping a + mold of pine dowel using a oscillating drum sander, drill press and router table, then created a epoxy - mold of the pine dowel in 2pcs a left and right, doing this made it easy for me to fine tune the shape by adding or subtracting material. Then using braided glass and epoxy I make the finished tower out of the - mold. This only took about 5 hrs. After experimentation I found the size and shape that worked best. The towers are about 3 5/8" tall with the smallest I.D. of 11/16" the output of my nozzle is 1/2". This may be hard to explain.,On the top of the tower I mounted a brass tube I made into a ring. Think of a circle now in dead center of this circle draw a line from there straight out at 6 and 3 O'clock on the inside of the ring. With very small holes drilled at the 2 O'clock. That 1/4% cutout between 6 and 3 O'clock was hanging over the inside edge of the top of the tower. On either side of this ring I braised in two little nipples that I attached silicone tubing that run to a fish tank bubblier " little air-compressor " making a curtain of low pressure of air around the top of the tower. This took a couple days. I wanted to make then out of spun stainless but I found that the fiberglass towers with a polished gel-coat finish, was better as the surface was so smooth the water slid right off.
- Next and I hope I'm explaining this well, an your following me. When I started I tried blades of many shapes and sizes which some worked but all had that splash forced back on top of the nozzle. So I tried diverting the water while I cut it! to do this I took a 1" copper pipe and split it down the middle. With a weeks worth of experimentation, what I ended up with was a that 1" copper pipe cut in half looking like a cesta used in the game Jai alai that looks very much like a beak on a bird of pray. There are 3 of these beak shaped curve hooked to a gearbox that rotates in the stream. When the beak cuts the water it also diverts it into a downward stream that isn't that broken up, so any water that is bounced back at the nozzle opening the hyperbolic tower clears away from the stream.
I hope you can make a little since of this to decide if its something you would like to try. I'll be back from vacation in a couple of weeks, when I get back I will be constructing two more nozzles for the fountain I just fabricated at my business. I will post pictures and video of the build and will post some video of a stream running with a knocker I've built to show another member of the forum.
P4H
P4H
punkforhire- Nozzle Newbie
Thanks again P4H, Always so helpful. Can't wait to see the pictures and videos!
any videos in the cutting section of this forum ?
I really need a working cutter on my Jet now
Would love to have a step-motor cutter, but I dont know how to build one.
Any one here that would like to build and sell a driver for a step-motor?
If not, anyone have pics of cutter that works ?
liteglow- Admin
You could build a driver easily !
*They* make single chips to drive it like the ULN2003 which allows 500mA per channel or higher ones (ULN2065 for 1.5A and on). There are tons of others but it's really that simple. You just attach an external power source to the stepper and the ULN (find the correct sequence) and get going with whatever programmable controller you have.
The rest is just the mechanical part which, judging from your pictures, you could easily do...
Jagi- Nozzle Newbie
cutter
I built 4 laminar jets for our Science Museum. I did a lot of experimenting with electro solenoids. I had a few 60 inch oz. electro magnet seloniods with 1" of travel. The problem I found is that the 60 in oz. of force is the last 1/4" of travel. When the piston is extended there is not much power at all which makes the seloniod unreliable, one day it would work the next day it wouldn't. I did find a larger electro selonoid that would work but it took 1 amp which I think is dangerious especially in a public display. I switched to pneumatic ,cylinders much safer. It is 1/2" in diameter and delivers 6lbs. of force at 20 psi the entire length of travel which is 1".
Glenn
Glenn
gwoodward- Nozzle Newbie
Jagi wrote:You could build a driver easily !
Thank you for the info..
This is really interesting !!
But I have absolutely NO idea how to get started
Can anyone help out with a (eBay) link of a stepper motor I should buy ?
And where to get started in the progress of a driver?
What I got today is relay to turn ON or OFF the signal..
thank u
liteglow- Admin
Well I'd start with finding a stepper instead or purchasing one. You could calculate the pressure exerted by the jet on the cutter's knife and then acquire the torque required from the motor, but I don't think it's very easy considering the geometry. I'd start with salvaging a stepper off an old printer/CD-DVD-hard drive/scanner and so on. The strongest ones will probably come from a printer and have a resolution of around 1 degree per step (far more then we need).
Once you have a stepper you need to identify it (Bipolar, Unipolar) and find the correct sequence to activate it. Again... Google... ("identifying a stepper" or such).
Parts for a driver:
Controller: Unless you want to delve into electronics - use a programmable controller with at least 4 channels (Arduino or such).
Power source: depending on your salvaged stepper, usually 12-24VDC. I used a converted PC power supply (Google "How to Convert a Computer ATX Power Supply to a Lab Power Supply").
Driver: Almost all steppers salvaged this way will run using the basic ULN2003. It should cost a few dozen cents (depending on qty.). ULN's are simple Darlington arrays which issue high voltage from you power supply when receiving a low voltage signal in the appropriate channel from your controller.
If you end up needing a larger stepper - all you have to change is the stepper (which you would probably have to buy then) and the ULN (very low cost).
Helpful I hope... ?
Parts for a driver:
Helpful I hope... ?
Jagi- Nozzle Newbie
thank you
i will look into it.
liteglow- Admin
step motor driver ?
http://www.goodluckbuy.com/arduino-dual-stepper-motor-driver-shield.html
motor ?
http://www.goodluckbuy.com/arduino-5v-4-phase-5-wire-stepper-motor-2-pack.html
How do you manage to get the motor to turn only 20-30 degrees ? and not all way around.
motor ?
liteglow- Admin
Page 1 of 2 • 1, 2
Similar topics» Archer build
» Second Build- Complete
» Character Build Guide - Break Down
» 90g discus, cory tank build log
» Wood prods, general question
Page 1 of 2
