Degrading stream for LED at night
Degrading stream for LED at night Empty Degrading stream for LED at night
Post  jetty on Mon Aug 22, 2011 7:57 am
Tested one of these yesterday evening, and I was pleased with the results. IMHO it's easier than injecting bubbles. It's a small 1G vibrating motor with a 3M sticky pad. Just stick it to the top plate. Would be easy to attach to a micro controller with a couple of resistors and transistor, or straight to a 3V battery. 3V @ 80ma.
http://www.hvwtech.com/products_view.asp?ProductID=694
It interrupts the stream enough to make the LED light the stream, but the stream remains cohesive. It's very quiet on the jet side. Where the water enters the pool on the other side, you can hear the vibration, but this would go away if you're using screens or foam at the other end.
A pager motor would probably work too.
jetty
jetty
Degrading stream for LED at night Empty Re: Degrading stream for LED at night
Post  rocketradio7 on Thu Oct 13, 2011 5:29 pm
Will you be posting videos?
rocketradio7
Post  jetty on Thu Oct 13, 2011 5:35 pm
No, because I'm now using a better method. Better because there are less parts. I'm doubling up the stepper motor cutter for stream degradation, by vibrating the stepper motor. This is because you're not cutting when you want a degraded stream at night.
See this thread: http://laminar.forumotion.com/t283-jetty-s-wifi-web-based-laminar-jet-project
jetty
jetty
