The effect of using steel filter ! (maybe no need to use straws?)
Post  liteglow on Fri May 08, 2009 4:14 pm
I just want to show you how effective the metal filter is , and what it does to the water..
Check out this picture:
It`s water falling down from the tap on my kitchen (normal speed) !
And you can see how clear the water is after hitting 3 layers of metal filters.. (from my kitchen)
I just wonder if this filter will have any effect into the laminar nozzle ?
And how many would wee need to eliminate the need to use straws..
Smile
Any thoughts about this ?
easy
Post  pbracer on Sat May 09, 2009 5:27 am
If we use my pentair as an example the number is 4 screens and two disks before them
The key is that the holes need to be decreasing in size as they approach the outlet
Re: The effect of using steel filter ! (maybe no need to use straws?)
Post  liteglow on Sat May 09, 2009 5:30 am
pbracer wrote:The key is that the holes need to be decreasing in size as they approach the outlet
Oh.. I did not know Wink
Thanx for sharing that !
Post  Magic-nozzle on Thu May 14, 2009 2:37 pm
Nice Test filip, looks amazing, yes, the right combination in the nozzle will replace the straws and the sponge. You can try fith fly mesh, first, 1 layer, second 2 layers and so on, i am shure this will work.
