Cutter vs Solenoid Valve
Hello all,
I have been building laminar jets for a few years after running across one of the early "Wet Design" patents (I am a patent searcher). I am about to build a few to put around a swimming pool and I would like to find the best way to control the start/stop effect. I have seen several posts (liteglow) concerning the use of cutters to create the stutter effect on the stream. Would a fast-acting solenoid valve at the inlet to the nozzle canister create the same effect? It seems with the cutter there is a constant steam of water that is either streaming to the receiving pond or being diverted by the cutter and draining back all around the canister. I would like to mount the nozzles into the deck surrounding the pool so I don't want water that is diverted by the cutter making a mess.
Does anyone have any experience with solenoid valves controlling flow to each nozzle?
Thanks,
Cal
Thanks,
Cal
Re: Cutter vs Solenoid Valve
Yes, a solenoid works just fine. I started out with a solenoid, but then moved to a stepper because of the amount of noise that the solenoid injects into the system. It's just with that hard stop the stream gets a bit muddled.
As far as the water splashing everywhere you will need to contain the water when it is cut somehow, or you will have water everywhere.
Last edited by John on Wed Sep 01, 2010 11:26 am; edited 1 time in total (Reason for editing : clarification)
