Magic_Nozzle's Laminar Project
Page 3 of 3 Previous  1, 2, 3
Re: Magic_Nozzle's Laminar Project
Post  John on Mon Apr 27, 2009 7:01 am
That really is pretty awesome! I'm amazed at how you did that. So all you did was replace the solenoid with stepper motors? Did you gear it up or anything?
So in your opinion, why is the stepper better than the solenoid?
Post  Magic-nozzle on Mon Apr 27, 2009 11:08 pm
John wrote:That really is pretty awesome! I'm amazed at how you did that. So all you did was replace the solenoid with stepper motors? Did you gear it up or anything?
Hi John, thank you.
Yes, i replaced the solenoid with 1 stepper motor. Mounting is very easy, direct on the axis of the stepper is the blade attached. The pros are using this kind of turning solenoid, stepper is similar, but you can stay in any position as long as you like, with a turning solenoid not. The special formed Blade is made from Brass and Cupper, all is braze (Hard-solder) together. I did some kind of a water tight sealing between Motor and the Blade, i described earlier how, with thickly and a Teflon part.
On the picture you can see the testing setup with scotch tape arround the solenoid, now i will build the pro housing arround the stepper motor and seal it.
The Reason why i change is, i have a lot less vibration than with a solenoid, the stepper needs no keystroke. Maybe i had more vibrations like you, because i used a self made solenoid.
Like it is now, this is the best cutting solution i ever had and i stay with it, i want to go on with this project. But maybe some other solution will work same good or better than mine with a solenoid. I cant wait to see what other develop.
Post  John on Wed Jul 29, 2009 3:38 pm
Mario,
How did you attach the blade to you stepper motor? I'm done playing around with my version of the cutter. It never really took off the ground because it was too complex. Maybe if I had a machine shop and a machinist I would get it to work, but I don't. So I have to work within my bounds, and that design isn't working in the bounds.
I'm going to use your approach on the design and use a stepper motor. I found one online for really cheap and it can hook right up to a microcontroller without any supporting chips. I just don't know how to attach the blade to the stepper.
Post  projeto on Wed Jul 29, 2009 8:30 pm
You rock...
projeto
Post  projeto on Sat Aug 08, 2009 7:28 am
I love that simple solution to let air out...anyway to talk you into making one more and send it to me? I pay you for it.
Dave
projeto
Post  Karlsson on Sat Aug 08, 2009 10:46 am
At Projeto:
Mario is still on holiday.
I do not know exactly when he comes back.
Karlsson
Karlsson
Post  Magic-nozzle on Tue Aug 11, 2009 12:33 am
John wrote:Mario,
Hi John, answer is here, some Pictures, sory i made the post in the wrong topic.
http://laminar.forumotion.com/laminar-nozzle-talk-and-pictures-f1/new-nozzle-20-with-pictures-problem-solved-t47-15.htm#795
The stepper looks not bad, i am not shure it has enough power to drive the blade verry fast. but try it. i use this one http://www.shop.robotikhardware.de/shop/catalog/product_info.php?cPath=69&products_id=172
and this controller: http://www.robotikhardware.de/download/rnstepp297.pdf
yes you need still a Uc to contrioll it but its so easy with this one. And you can set the current for the motor, verry helpfull.
Post  Magic-nozzle on Tue Aug 11, 2009 12:35 am
projeto wrote:I love that simple solution to let air out...anyway to talk you into making one more and send it to me? I pay you for it.
Dave
Hi, sorry, no, i just have not enough time for my stuff, you have to find a own solution that works for you, i can help you thinking, but not building it. thanks Mario
Post  covewi on Tue Aug 25, 2009 4:02 pm
Magic Nozzle -
On the first page of these posts I noticed that you are using threaded rods to hold the top and bottom plates to the tube body.
Are they stainless steel or galvanized?
Do you put a gasket or silicone between the plate and body tube?
I like the idea of attaching things that way any information you can share would be helpful.
Post  Magic-nozzle on Tue Aug 25, 2009 10:57 pm
Hi, this was my first nozzle, my new one is different, look here http://laminar.forumotion.com/laminar-nozzle-talk-and-pictures-f1/new-nozzle-20-with-pictures-problem-solved-t47.htm
On the first i use stainless steel threaded rods and screws, a 1/2 inch lexan plate on top, and a pre welded bottom. On the top i made a silikon line arround, wait 30 min to dry and then press the top on it, so the silicon has time to dry a little, works much better than putting it together with the lexan plate. Hope you understand what i mean. The rod princip is relly easy to use and works perfect. In the new nozzle i use turned top with a rubber ring inside, much easyer and no silicone needed. i can break it apart in 1 minute.
Good luck
