My Project
Page 1 of 10 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
My Project Empty My Project
Post  covewi on Tue Jul 28, 2009 5:09 pm
Thought I would post a few photos of the project I am working on. Its a 8" diameter 18" long jet.
My Project 9ie8i0
My Project 250369g
My Project 104nlhx
My Project Oqgo0o
My Project Wqirm
the "O" ring fits very tight around the tube which will allow me to move the fiber bundle up and down with the fountain in operation to adjust for the best lighting.
I will cement on a smaller plexiglass disc to sandwhich the "O" ring.
My Project 10799nd
My Project 2zrl5ax
My Project Empty Re: My Project
Post  John on Tue Jul 28, 2009 7:31 pm
how are you going to seal the lighting tube?
My Project Empty Sealing
Post  covewi on Tue Jul 28, 2009 7:43 pm
The bottom end is pretty much self sealing but I will put silicone sealant around the tube just to make sure.
I will be using Endglow Solid Cable, found at (near the bottom of the page)
http://www.fiberopticproducts.com/Endglow.htm
For the fiber optic lighting. I will simply seal the light end with silicone sealant. Possibly a clear cap of sorts could cover the end.
Post  liteglow on Wed Jul 29, 2009 6:13 am
Looking very good Smile
What LED will you be using ?
And how will you connect the led to the fiber bundle..
You use the same filter as I use Smile
My Project Empty LED
Post  covewi on Wed Jul 29, 2009 4:19 pm
I bought a 3 watt RGB LED on ebay... bright as hell... will connect an RGB controller to it too.
I have a small metal box which will hold the LED, heat sink and power connections.
One end will have a fiber optic connector to hold the cable.
The lens holder and collimator will be attached to the LED and sit in line with the light end of the fiber bundle.
Post  John on Thu Jul 30, 2009 9:52 pm
covewi,
Are you in the US? Where did you get the filter pads/articulated foam?
Post  liteglow on Thu Jul 30, 2009 11:58 pm
John: I bought my foam\filter from eBay !
Just search for KOI filter.. etc..
Post  liteglow on Fri Jul 31, 2009 6:47 am
Here is a eBay link to the filter I have in my nozzles:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250397744831&ssPageName=STRK:MEWNX:IT
My Project Empty Silicone
Post  covewi on Sat Aug 01, 2009 10:12 pm
First - John - Yes I am from the US. I have the same ebay foam in my filter and bought it at Home Depot - a home supplies store.
My question for everyone is - when sealing the top and bottom plates with silicone - do you place the plate on top of the ring and then seal the gap with silicone?
Or do you run the silicone on the ring and then put the plexiglass plate on top of the silicone.
Either way do you let the silicone dry first or do you place the plate or ring on top of the plate into the wet silicone?
Post  John on Sat Aug 01, 2009 11:49 pm
I like to silicone the inside and then place the plexiglass plate on while the silcone is still wet!!!! Make sure that you apply it liberally so that it will fill up EVERY tiny gap. Water will find even the smallest gaps!!!!
Thanks for the tip on the articulated foam!
Post  Therons on Sun Aug 02, 2009 9:35 pm
I put the silicone on top of the end plate and then put the end ring on while the silicone is wet. This way makes it easier to remove the end plate (if needed) by cutting the silicone from the outside of the plate.
Post  covewi on Mon Aug 03, 2009 12:47 pm
Doesnt the silicone spread out under the plate?
I tried this over the weekend and could not get plate out?
Any suggestions?
Anyone come up with a better way to "lock" in the top and bottom plates?
Post  John on Mon Aug 03, 2009 12:53 pm
Mario has this one.
http://laminar.forumotion.com/laminar-nozzle-talk-and-pictures-f1/new-nozzle-20-with-pictures-problem-solved-t47.htm#524
There is another one just like on the forum, but can't seem to find it! They don't have to use any silicone on there plates at all!
Post  liteglow on Mon Aug 03, 2009 2:32 pm
here is how I did mount the lexan glass on the top:
My Project 06072009983
My Project 03072009943
I have silicone, and then place the glass over it with many screws all the way around Smile
I can also remove the glass when the silicone is dry, and place it back again many times !
One more thing, I have some small leaking water from the top (maybe bottom also) but that does NOT matter at all in my project.
Because the laminar nozzle is mounted in water tank, and the "leaking" water just help to remove the air that is inside the nozzle Smile
I did drill one tiny tiny hole in top of my nozzles, that remove the air at startup..
And the tiny tiny holes can also be used to slow down the pressure if it`s to high.
My Project Empty photo
Post  covewi on Tue Aug 04, 2009 5:41 pm
I cut a small plastic disc and used silicone to seal it to the top of the pvc fiber optic tube.
I used a small "O" ring on the top and bottom screens of the straws - it really holds things tight.
My Project 2m65t7c My Project Nmx7v9
Post  covewi on Thu Aug 13, 2009 7:03 pm
No silicone - I secured the ring under the plexiglass with screws and placed a small diameter (aquarium tubing) around and on top of the ring - next i placed the 1" ring on and secured it to the tube - as you can see I drilled and screwed in 8 stainless steel screws around the perimeter and screwed them down to compress the tubing.
No leaks - no silicone - easy to take apart with no mess - did the same on the bottom.
My Project 28umy4k
First photo
My Project Ztyghy
My Project 25r2hyg
My Project 2hp0eb6
The splash down is 16 feet and probably 8 high
My Project Vosghl
Need to build a low pass filter this weekend and install the fiber optics
Post  Therons on Fri Aug 14, 2009 12:14 pm
Covewi, looks like a good solution, but I wonder if the tubing will flatten over time and leak. Are you able to compress it enough to collapse the tube?
Great looking stream over a long distance!
Post  covewi on Fri Aug 14, 2009 2:39 pm
The tubing is stiff yet compresses well - that's what I wanted. I probably flattened the tube by half .
I will have to take notice - if over the long run - if it starts to leak - hope not.
What software and hardware were you talking about using from
http://www.lightorama.com/
Bye the way are you from Missouri or maybe TN?
The country side looks like both.
Covewi
My Project Empty LOR board
Post  Therons on Fri Aug 14, 2009 4:24 pm
Light O Rama announced a pump and LED control board a year ago but have not been able to produce in qty. You can see the spec. sheet here: http://www.lightorama.com/Documents/MLC-100.pdf .
Actually I'm in Utah. Where are you located?
Theron
Post  covewi on Fri Aug 14, 2009 11:26 pm
Theron
Thanks for the info - I am in the Chicago Suburbs.
My Project Empty veins in the stream
Post  mrwebb on Sat Aug 15, 2009 2:47 am
Hi covewi and guys.
On covewi's closeup picture you see small veins. I would like to know if they result in turbulance and splashing
in the middle or end of the stream. For me thats kinda the case. Its like that if the orifice is not sharp enough
(maybe small craters on the edge) small veins end up getting bigger on the path and get turbulent.
I think Filip (liteglow) also had some problems with that the pumps frequency affected the stream.
What are your experiences?
By the way, i love your design covewi. Better than using silicone.
Regards Steffen
mrwebb
mrwebb
Post  covewi on Sat Aug 15, 2009 8:39 am
Your probably correct about the cause of the veins. I took a close look at my brass ring and there are some very fine lines on the razor edge.
The next best thing would be to polish the edge or have more accurate ring milled.
I am using a 2.5 HP that is used for our small swimming pool - I have no idea of the GPH output but believe it is very low - this too could effect the stream consistancy.
Post  Therons on Sat Aug 15, 2009 9:34 am
Therons wrote:Light O Rama announced a pump and LED control board a year ago but have not been able to produce in qty. You can see the spec. sheet here: http://www.lightorama.com/Documents/MLC-100.pdf .
I emailed Light O Rama yesterday about the MLC-100 board and got the following reply:
"We have decided to build a small number of these in the US. The large build in China has simply taken too long -- years at this point. I sent the information out early today and am awaiting the bid to build here in NJ. Usually the build time is 4 to 6 weeks so we will miss another summer, but at least we will soon have some real units that people can buy. Sorry for the delay. Had we know how messed up the China buld was going to get we would have started this build last March."
So I guess I'll wait a little longer.
Post  covewi on Sat Aug 15, 2009 12:30 pm
Newest photo
https://2img.net/h/oi26.tinypic.com/29gkfoj.jpg
Post  mrwebb on Sat Aug 15, 2009 1:40 pm
very nice... i love it !!
mrwebb
mrwebb
