Knocker idea ...
Knocker idea ...
Ok, on my way home from the workshop after creating some nozzles, I was thinking about how to make the stream interact with music.
Then it popped into my head .. why not just feed a knocker with audio? Sure it would require a large amplifier, and probably wouldn't be a permanent setup, but it should create an effect that when you have bass, you get the classic jumping water effect, but to the beat of the music!
Combine that with a micro controller with an audio input, you can have the stream "pulse" to the beat, and also colour change!
Heck, you don't even need an audio amp on the thumper, just connect that to your microcontroller via a MOSFET and have the microcontroller detect the beats.
What would be kind of cool is a microphone input. SO you can stand next to your fountain, and "clap", and the light will leap
Just a bunch of random idea's, though I intend to try them out once my nozzle is working perfectly.
-Dan
-Dan
Things- Nozzle Newbie
Re: Knocker idea ...
We like random ideas :-)
And the idea sounds like cool..
Problem can be if there is in the city, and there is allot of other noise in the background.
Dont you have laser? do you have a laser software like mamba etc... ?
It can be cool to use the output from a DAC and connect that into the knocker\cutter\RGB light.
Then you can program the nozzle with music..
That was also my random idea someday....
Heheh, you can do anything with microcontrollers! You could control your fountain from DMX if you want!
My scanner is apart for repairs at the moment, my 640nm laser-wave red had to go back for RMA
» What Pump to use ?
» Servo motor for cutter
» Idea for nozzle tube?
» Designing the Perfect Cutter
» IDEA: immersed LED, no fiber
