upgrade from 3" to 5"
Post  jahroen on Sat Sep 03, 2011 3:29 pm
i just finished my 5" nozzle
10mm nozzle exit,
2500LPM pomp,
20mm hose with 2 inlet holes at the botten of the nozzle.
i made a short daytime and nighttime vid
jahroen
jahroen
project expansion
Post  jahroen on Wed Sep 14, 2011 8:40 am
going to make 3 more nozzle,s
my parents liked it so much they like to have 4 now. bounce
the 5" seems to work just fine so ill stick to that.
updates along the way
jahroen
jahroen
Re: upgrade from 3" to 5"
Post  Jurrien on Sat Oct 01, 2011 1:08 pm
Hi Jahroen,
Your project looks very very interesting to me, because it seems that you are using the same PVC material. I have also build a 5 inch nozzle with a removable cap and bottom. What have you used for the outlet? I am using aluminium sheets. I also have found someone with a column drill. Unfortunately, there was ample time for experimenting this summer, because there was too much rain.
Jurrien
View user profile http://lego.roerei.nl
aluminium
Post  jahroen on Sun Oct 02, 2011 5:39 am
aluminium tube is what i use to make the exit hole, tube is 20mm hole is 10mm.
i dont use any powertools just a saw and sandpaper
i made a small vid of the 4 nozzle,s
jahroen
jahroen
update
Post  jahroen on Fri Oct 07, 2011 2:20 am
aquarium filtersponge instead of straws.
what first looked like pomp jidder was actualy uneven pressure in the lower part
of the nozzle and got transported via the straws to the top of the nozzle.
so by replacing the straws with aquarium filtersponge i got rid of most jidder in the stream.
this is without the lowpassfilter .
jahroen
jahroen
Post  liteglow on Thu Nov 03, 2011 2:34 pm
great progress ! Smile
Straws is not always something you need to make a laminar stream.
all you need is to make the water flow slowly up to the top without any turbulence.
