This is my first Laminar Water Flow Nozzle.
5 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Re: This is my first Laminar Water Flow Nozzle.
Hi Filip!
I'm sorry for answering so late but I am quite busy too.
Yes, I did it all.
The plastic pieces... I drilled it with an hexagonal bit... no, no... just kidding!
I designed the pieces in a CAD and then cut it with a laser form a 2 mm thick acrylic sheet.
Here is the pieces design.
I have had not enough time to experiment some variations that I have in mind yet but I will be getting back on the nozzle soon.
I hope will be able to take a better video the next time.
Thank you a lot for your kind comments and compliments and also thank you again for creating such a great forum.
I would've never been able to achieve the construction of my little nozzle without the huge sharing that I found here. Thanks to you all!
Cheers!
Leonardo.
Yes, I did it all.
Cheers!
Leonardo.
Leonardo- Nozzle Newbie
Wow, this looks cool, do you have a Laser cutter at home?
LASERS! I'm drooling! I wish I had a laser cutter (or access to one)!
Is there any particular reason you went with hexagons instead of circles? I don't even know if there is a difference, but you may want to check into that.
Hey... Hi buddies!
Yes Mario, I do have a laser machine. It is an old 25 watts Epilog Summit but I love it.
John.... your wish list is growing and growing! After the lathe a laser machine will be a great addition to your workshop!
The reason because I choose the hexagons is that they can be arranged more efficiently than the circles with a better control of the inter spaces. I mean I was able to control the wall thickness between the hexagons balancing the total cut area with the piece strength. Just an experiment!
All the best,
Leonardo.
All the best,
Leonardo.
Leonardo : That is awesome !!!
wow you have your own laser cutter .. give me some pictures
I have 1,5W green DPSS laser that can cut small plastic haha .. (and one 1W RGB laser)
But wow 25W is allot of power. (maybe you should visit www.photonlexicon.com forum)
The work you have done making that small nozzles is just incredible!
Thank you also for the kind words but remember YOU and everybody on this forum is what make this forum great !!
All the info YOU and the other shares is helping everybody
Hi Filip!
I'm afraid that you are confused about the laser. My Epilog Machine is in fact at the lower end of the power scale for CO2 laser engraving/cutting systems. Although the laser tube is 40W the machine is rated at 25W witch is quite enough to cut a 6mm plywood or acrylic sheet. I am attaching a picture of the machine.
Hey... I visited the photonlexicon forum... quite interesting! Thank you for the link.
Kind regards,
Leonardo.
Kind regards,
Leonardo.
Ohh man, what a COOL THING! i WISH I HAD ONE OF THISN GUYS AT HOME.
Mario, what are you waiting for? You've finished your fountain!!! You should have LOADS of spare time now. It's time to start making your home built cnc laser cutter!
John wrote:Mario, what are you waiting for? You've finished your fountain!!! You should have LOADS of spare time now. It's time to start making your home built cnc laser cutter!
Yes, why not!, I try to build one, i think in 2 weeks i made my cuts!
No, that is really to dengerous for me ... A plasma cutter, why not, but a 25W laser cutter .. Huhhh!!!
No i am actually try to connect two microcontrollers with air a transmitter, 2x RFM12, ohh man this is such hard work, transmitting and menaging bytes by bytes to the air and recieve it, i need to learn so many things about bytes sending nad recieving, but in a view weeks i think can send and recieve my own bytes over the air.
And then i try to make a remote 100W Laser cutter! .. No, i am joking.
I was working on a problem that was doing the same thing sending byte via RF. I got some code to work pretty reliably, but it IS VERY HARD!
I suggest using the UARTs on the chips! http://en.wikipedia.org/wiki/Universal_asynchronous_receiver/transmitter
But I'm sure you already know that.
I`m not confused
But I still think that 25W is allot of power in a laser..
When I know how dangerous all lasers above the 200-300mW limit is !
Not to mention what a 200mW laser can to to a eye !!
I notice how "small" in size your box is, must be handy to have a laser cutter like that in the office
btw: The photonlexicon forum is a forum a friend of my did create some years ago.
That have grown pretty big now, there are mostly show-laserists there.
But we all like to see a laser, no matter if it can Cut ore make some stunning light-effects
feel free to join the forum if you want to share your laser in there :-)
but plz stay on this forum also haha..
one more question, do you also cut\write in glass with your laser?
Can I ask what you did pay for that nice machine ?
Hi friends!
Let's talk a bit more about my laser machine.
When I arrived to Spain in 2001 I bought a Gravograph IS200 engraving machine to start my engraving business. After some months I realized that I was loosing customers because the little IS200 engraving area so I started looking for a laser system.
Oh man! That machines were really expensive (30 thousands and over) and I did not able to afford even the more economic one, but I really was in the need of expanding my business...
Then I started looking for a used one... after a couple months I found this machine witch were way far of a "mint condition" but they asked me only 7000 euros! This was in January 2002.
I have to disassemble the axes, clean it, lubricate the bearings and realign all the system. Also have to replace two mirrors... The Epilog representative asked me 350 euros for that pair of mirrors but I found a pair of 1/2 inch, excellent first face silver plated, coated mirrors in Edmund Optics for 72 euros each!
After that I also added a laser pointer and an air assist system.
That's was fine and the laser machine was working but the laser tube was discharged and needed to be refurbished...
In this moment I was lucky enough to got a commission to engrave 3200 pair of scissors from a cutlery... WOW... they paid me 1,20 euros each! That was great because I sucked the last drops of juice from that dying tube and had the money to repair it and more important, having earned the money with the machine itself. So, I pulled it out of the machine and sent it strait to Synrad that is the manufactured and they send it back to me almost new with warranty and 10 thousand hours of use ahead!
All of this was in a lapse of six month and I spent about 4000 euros repairing the machine (plus my hours) but the machine is running perfectly until today!
Oh guys! Please, excuse me for rumbling you so much but I enjoyed very much that hard new begin as an immigrant here! You have remembered me those funny days! That was really great!
Filip, all of the above was to tell you how much I paid for the machine... hahaha!!
Today is possible to buy a brand new machine for less than 9000 euros. The Epilog Zing is a great little laser system that is about or under that price.
Ahh... yes, it is possible to etch glass with the laser but you cannot cut it.
Regarding your friend's forum, unfortunately I have no time to participate in other forum. Forums are very addictive and I am participating actively in an engraving forum that is almost part of my job and now in the Laminar forum, anyway I will visit the photonlexicon forum from time to time.
All the best!
Leonardo.
All the best!
Leonardo.
Great story
I understand that the time is running out when we log into the "internet" haha
I got the same problem... (as I got at this moment... to much to do around in the house)
Anyway, I love the work you have done with your machine and the work you do with it !!
Very impressive
Now I know who I can give a call if I want a custom made laser engraved glass plate
Very impressive
Hey Filip!
Just give me a call and I will be glad to engrave any plate you need.... even more, I will be glad of taking it directly to Norway to give it to you in person!! hahaha
Seriously, I would love to see the famous Norway fiord's some time.
Kind regards,
Leonardo.
Kind regards,
Leonardo.
NICE
I dont know what to engrave but it sure does seems like fun to have a personal engraved something....
btw, yes whoever visit Norway, I for sure help you out to be a guide
you can see some pictures here: https://laminar.forumotion.com/introduce-yourself-f2/liteglow-from-norway-t1.htm
And if you do some google search you sure find allot of more pictures.
Ahh there is one more thing, my mother actually own a house in Lofoten in Norway (where my grandparents did live) !
And if anybody here want to take a holiday in Lofoten, I gladly rent out the house out for you :-)
Hi Filip!
Thank you a lot for your kindness and the nice offer.
I told my wife about the possibility of renting your mother's house for some days and she was very exited with the great opportunity of being there for a little vacation.
We both like very much the Viking culture and knowing Norway is always in our short wish list.
By the way... I am attaching a picture of my Viking chairs. I made it eight years ago with some wood that I had available. They were really funny to built and are so comfortable that always calls the people attention. Really a great, simple and millenarian design.
Kind regards,
Leonardo.
Kind regards,
Leonardo.
More info
Hi Leonardo
Can you please publish dimension of your Laminar and some more picture showing how it is assembled.
Hole sizes etc.
YS
Hole sizes etc.
YS
yogeshsharma- Nozzle Newbie
No plans.
Hi YS,
Unfortunately, I have no plans of that nozzle. I did it "on the go" with the materials that I had available in the workshop, and only did some sketches at the time of machining the threads (lost in the mess!).
The only parts that I have properly documented are the the acrylic grids because I cut it with the laser so it was a must to have a CAD design to sent it to the machine in vector mode.
I can not promise anything in this moment, but, if I have some spare time, I will look to take some measures from the nozzle and drawing the plans. But it will not be possible before a couple of month... sorry!
Regards,
Leonardo.
Regards,
Leonardo.
Page 1 of 2 • 1, 2
» My first try at a laminar flow nozzle
» Aluminum Outlet - exit hole for laminar flow nozzle
» For what reason can the laminar flow be dispersed?
Page 1 of 2
