let there be light
let there be light
The video was taken with my cell phone. At the moment it is all I have.
rocketradio7- Nozzle Newbie
Re: let there be light
Cool. Jet seems very stable.
What design are you using for the low pass filter and which pump are you using?
jetty- Nozzle Novice
The low pass filter is standard 2ft by 4 in. Pump is just something that was cheep. Will add pictures as soon as I find out how.
Streem is ok but I think it should be more stable.
Ok found out how
Ok found out how
That looks really stable!!!!! And the light looks great too! Well done! Thanks for sharing!
Thanks John
Tried somthing today I saw from zac on u-tube. Added tee and small bottle to output of pump. Might have slowed streem movement a bit but applacation was wrong and bottle leaked. Have some work to do. Also need to start thinking about a cutter. Are you going to post any more videos of your nozzle?
David
David
David,
I have to be honest. I took mine apart a couple of years back and have never put it back together. I got close on the cutter. I had the LEDs working but I never
Got all the way there. I've also put it on hold as I'm trying to start a sign business on the side using my CBC router.
I'm glad I did hold off til now. The LEDs are sooooooooo much brighter now! Speaking of what and where did you get that 40w led?
I understand how life gets in the way of our hobbies. Your video is what me started. The LED is the same as covewi uses and I thing so is the cable I use. If the link works I got it here.
http://www.mouser.com/ProductDetail/LedEngin/LZC-80MC40/?qs=wM7Mpho15MRmb5Mnn4w07A%3d%3d
Last edited by rocketradio7 on Thu Oct 13, 2011 5:26 pm; edited 1 time in total (Reason for editing : referenced wrong person)
I know this is a little old so sorry for posting in it. Kind of curious.
I'm assuming your LED's are on the right hand side of the box, if so what are you using to get the light down to the larger fiber cable?
Also what are you using for your larger fiber cable?
Thanks in advance.
Thanks in advance.
twooly- Nozzle Newbie
HI Twooly
The led is in the bottom center. My cable comes from this place http://www.fiberopticproducts.com/store/index.php?cPath=8_19
It is 14mm solid core end glow.
» Light up the stream?
» LED Light question
» Interesting Light module !
» Liteglow`s twin Laminar Jumping Jets :)
